coolant issue
Old Mar 30, 2012 | 10:24 PM
AudiSw4g's Avatar
Default coolant issue
Today while driving on the highway my coolant temp. went way up. It kept dropping to normal then back high. It mainly happened when i went over 50mph. Has anyone else had this issue?
Im still new to audis, and i was wondering if i could go to auto zone or someplace and get some g12 coolant and put it in. And can i just top it off or do i need to drain the current coolant i have. Thanks
Old Mar 31, 2012 | 12:50 PM
Audi Tek's Avatar
Tech Certified
You don't need to drain any coolant. you can top it off if needed. You may have a flow issue or a malfunctioning thermostat.
This is an issue with a few possibilities
Old Apr 5, 2012 | 06:45 PM
Karl's Avatar
I am going to take a wild guess here.. Does the temp stay normal at speed, but when you idle the temp goes high?? If so, the problem is your water pump. The impeller is plastic and when it cracks and breaks it wont spend at all when just idling. But at high speeds it gets enough momentum to spin the impeller. Easy to replace the water pump.
Sean1234
Nov 18, 2013 07:49 PM
DENIS415
Jun 24, 2009 02:09 AM
j_ripper19
Mar 30, 2009 01:09 PM
Remman
Mar 15, 2008 09:59 AM
silveraudib6
Mar 12, 2008 10:59 AM
