Coolant leak near engine block
Old Oct 26, 2013 | 03:24 PM
Kellydeane's Avatar
Default Coolant leak near engine block
I have a 1.8t engine with a coolant leak. The closest I can trace the leak is there are two bolt at the bottom of something called helmholtz resonator (I think) and these bolts are covered in dripping coolant.
The bolt the resonator thing to the engine block and I'm fairly sure the resonator thing doesn't have coolant inside. It's for air (I believe). So I can't figure out where the coolant is coming from.
Any ideas of where to look or why I might see coolanf dripping here?
I'm determined to find and fix this leak myself, but I'm a girl and not exactly super familiar with this. Any help would be appreciated.
Thanks!
Kelly
Old Oct 26, 2013 | 10:25 PM
Nebuchadnezzar's Avatar
Are you seeing this towards the back of the engine? Are you referring to the down pipes off of the turbos?
I'm going to take a wild guess here and say it's coming from your upper coolant temp sensor located towards the back of the engine, a little off center favoring the passenger side. These flanges are known to go bad from time to time.
Old Oct 27, 2013 | 12:26 PM
Kellydeane's Avatar
It is nearer to the passenger side, but after looking again it looks like it's near the front of the engine block somewhere above the helmholtz resonator, but it's tough to see exactly.
Old Oct 28, 2013 | 12:05 PM
pa4ul's Avatar
hmm can u take a pic and post it?>
cudafish
Aug 15, 2021 04:24 AM
caozam
Oct 15, 2014 01:54 PM
uscourt3000
B7 Models
Oct 23, 2012 07:31 PM
a4audia4
Sep 10, 2010 09:18 PM
zippy_gg
Jul 13, 2009 03:28 PM
