Coolant leak, rear of AMB head.
Old Aug 28, 2012 | 05:36 PM
Ralf5k's Avatar
Default Coolant leak, rear of AMB head.
I have a coolant leak at the rear of my AMB cyl. head. Vehicle has been sitting off and on for a while. I've started to disassemble, but it is going slow due to arthritic hands. The only thing back there I believe is a coolant flange with CTS plus hoses. Any likely possibilites? I have a ton of experience with older Audis up to mid nineties, not so much hands-on for later models.
Any suggestions would be helpful.
Old Aug 28, 2012 | 05:50 PM
pa4ul's Avatar
coolant flange. U headed in the right direction.
Old Aug 29, 2012 | 11:31 AM
MKE_Audi's Avatar
coolant flange for sure, $30ish part from dealership. Just a pain to get to and peel away all the layers of hoses, etc. Do the CTS while you are there.
Old Sep 22, 2012 | 12:24 PM
e@dyab's Avatar
im trying to get to coolant flange, it is a pain, if you have any tips be greatly appreciated
Old Sep 22, 2012 | 06:15 PM
Audi Tek's Avatar
Tech Certified
Un bolt the heat shield on the left side, The 6mm allens too....... this way you can move the metal line that goes over out of the way.
I also use a jack on the tail shaft of the transmission and raise it gently and slowly and only a little bit to tilt the motor forward to give your hands about 3-4 more inches of space.
Its still a PITA regardless
Old Sep 23, 2012 | 09:32 AM
e@dyab's Avatar
Smile ty
thanks for info, mine is a 2002, so I think its not the AMB moter, little different set up. But the info was great.
Paul Aston
Jul 1, 2013 02:10 AM
mtroxel
Jul 28, 2012 12:07 PM
99A4NOW
Jul 23, 2011 01:03 PM
slideleft
Aug 30, 2010 12:14 PM
Jjedlicka
Aug 2, 2010 09:13 AM
