Crankshaft question
Old Jun 17, 2012 | 03:45 AM
Sebat's Avatar
Default Crankshaft question
so long story short I had a water pump leak and I had to replace the gasket... anywayz when I put my timing belt back on and tried to tight all 4 screws on camshaft rollers my crankshaft moved by one tooth (i didnt use the lockpin but my camshafts are locked with the lock tools) so now my question is can I move it back that one tooth w/o any issues ? Also is it ok to move crankshaft back and forth like that by a tooth or two or w/e just asking to check if my in case i move it to far and the timing on the cover and the crankshaft pulley is off and I will have to adjust it.
Old Jun 17, 2012 | 01:14 PM
Audi Tek's Avatar
Tech Certified
Just be carefull when turning the crank, there are two kinds of resistance..... compression and a valve. You don't want to turn against a valve.
More than 2 teeth and its most likely a valve.... But yes you can to adjust the timing. But i would install the bottom plastics and crank pulley and make sure your using the audi timing marks, not the ones you made
Old Jun 17, 2012 | 01:54 PM
Sebat's Avatar
Yeah, i just moved it back and forth with the plastic and pulley on to adjust it to the Audi timing.
Another question though, after installing timing belt I need to set exhaust adjustment variable using audi special tool T40028 can someone tell me what it does and what happens if i mess it up and turn it too far or can i turn it too far ?
age2k2
Feb 27, 2014 10:51 PM
chrisWRX
Sep 15, 2012 02:32 PM
hear99
Aug 15, 2010 01:27 PM
blackedoutaudi
Jan 3, 2010 03:23 PM
zensane
Aug 25, 2006 04:16 AM
