Difficulty Starting????
Old Mar 4, 2010 | 09:49 AM
Vaalie30's Avatar
Default Difficulty Starting????
I have a '02 1.8t. It is having a hard time starting. It turns over fine, but it sounds like it's either not getting fuel or spark.
Has anyone run into this issue and/or know what it could be
Thanks
Old Mar 4, 2010 | 10:48 AM
shane.trammell's Avatar
probably the engine speed sensor. has it died or given a check engine recently?
Old Mar 4, 2010 | 12:18 PM
Vaalie30's Avatar
It's hasn't died or kicked out a check engine light. It is worse when it sits for a while.
Old Mar 4, 2010 | 12:20 PM
Make sure there is fuel at the rail. Turn the key over and push the schrader valve at the end of the fuel rail.
Could also be a dirty throttle body..
Old Mar 4, 2010 | 06:01 PM
Dan1969's Avatar
So if the car doesn't start, it could be your fuel pump, if the car starts run diagnostics, it could be like shane suggests the speed sensor (G28) or the coolant temperature sensor.
zhouge
Nov 15, 2013 07:45 AM
badshovel
Jun 13, 2013 10:33 PM
qwert
Mar 4, 2007 04:34 AM
GreenMachine99
Aug 15, 2006 02:55 PM
david9999
Jun 5, 2006 03:34 PM
