:: ECS Tuning :: NEW!! ECS Billet Aluminum Dipstick | B6 A4 1.8T
A clean car says a lot, but the real talking starts when you open the hood. So if you're looking to make a statement, you'll need a clean engine compartment that says “high class”. If this is for you, we have the perfect solution!
Straight from the engineering masters at ECS Tuning comes our new oil dipstick, and we promise, this is a lube-level like no other. With a billet aluminum handle and stainless steel cable, the quality is second to none. The butter-smooth grip is easy on your fingers, and the easy to read stainless steel indicator is the best there is.
ECS Tuning's Billet Engine Oil Dipsticks feature:
- Comprised of 1x7 stainless steel wire rope, topped off with a billet aluminum 6061-T6 handle finished in one of three color choices (Polished, Black Anodized, & Silver Anodized).
- Stainless steel bullet shaped indicator designed to match up with the OEM specified 'Low' and 'Full' oil level marks.
- All dipsticks are pull-tested to ensure a rigid, crimped connection and every handle has pre-installed dual viton o-rings for maximum sealing capacity and oil/fuel resistance.
- Engineered in-house and manufactured in the U.S.A., you can expect nothing short of the very best quality in terms of fitment, precision, and longevity.
- Billet Aluminum Dipstick Tube! Made of 6061-T6 aluminum, fully TIG welded, and anodized black for corrosion resistance, this tube is engineered for maximum durability! A machined aluminum and black anodized mounting bracket is also included for a tight, OE fit and includes a stainless steel securing bolt.
Clean Looks
Click HERE to order or for more information
Fits:
Audi B6 A4 1.8T (2002-2005)
Be sure to check out our -----> Installation PDF
ECS Tuning
10-14-2015 01:48 PM
ECS Tuning
B7 Models
10-13-2015 12:41 PM
ECS Tuning
S3
02-02-2015 01:18 PM
