EPC light/Check Engine-Audi not finding issue
Old Jul 30, 2015 | 03:56 AM
  #21
Exuberantt's Avatar
It's so sad to read about problems that can't be solved in Audi A4 B6... I own one! Believe me the only reason I ended up here is how I could replace a burnt headlight... I went through hell to get it replaced.
I've had a lot of problems before with this model. Some that couldn't be traced by professional mechanics. 'Cause I couldn't afford THE STEALER! Going through reading and turning internet pages using three different languages (Norwagian, Dutch and English) helped me solve the problem by myself.
I got a friend who owns A4 B7 since 2007 driving the car with the Check Engine light ON 'cause THE STEALER couldn't and still can't trace the problem... The disadvantage he has is he can't know when there is a problem with the other parts of the car until he hooks up with diagnosis.
I'm telling you Audi cars are wonderful and comfortable cars to drive around but when it comes to maintaining them even a simple burnt bulb change will make you go through hell not to mention oil consumption. You must have extra oil on reserve...
Audi A4 B6 is my first Audi and I'm really saddened to confess its gonna be my LAST...
Good Luck with the PROBLEM. Hope you'll find a solution to your problem. Cheers!
Old Oct 14, 2015 | 12:29 PM
  #22
dweikert's Avatar
Default ESP light comes on and then Check Engine light comes on....
I have a 2004 A4 1.8T Q and lately my ESP light will come one first and a couple seconds later my check engine light comes on. I will drive anywhere from 1/4 mile to 10 miles and then the ESP light will go off and the check light light will stay on until I turn the car of and on about 8 times. At times I have plugged in my Actron Pocket Scan Plus OBD II Code Reader and it reads a P0102 Mass Air Flow Circuit error. I can clear the code and there is no difference in performance, which has always been very good. I have noticed that the engine will "stumble" for just a second and and within a second the ESP light comes on and then the check engine light. So I'm just clueless as to what to do. I don't want to go to the dealer, I feel like I am taken advantaged of each time I have gone in the past. I can do all of my own work.
Hope someone has some advise for me.
Old Dec 3, 2015 | 01:53 PM
  #23
claymor's Avatar
Default EPC Light - Engine dying - Loss of RPM's while driving
I had this going on as well on my 2005 A4 Quattro. I would be driving and I would briefly lose RPM's. If this happened when I was stopped, the car usually died.
I was kinda freaking out when I was looking through various forums about the EPC light and the vehicle dying. Especially when people were saying even the Audi dealership didn't know what the problem was.
I went to a local shop in town and told them what was going on. About an hour later, they called me and said that, to resolve this problem, I needed:
* A new crank position sensor ($100)
* New spark plugs ($48)
* New coil packs (4 @ $40)
Picked up the car from them and it has been running perfectly for about 2 weeks now.
Just my experience and what seemed to be the resolution for my EPC problem.
-c
Old Dec 10, 2016 | 03:16 AM
  #24
Blaise's Avatar
Default Epc light Audi a4 2002
Since about 2 weeks, my car is hard to start, it takes about 30 second (starter running). Then the engine start and the EPC light come on, enven if that one as been deleted right befor... No check engine or other light come on at this time... WTF??
Old Feb 11, 2025 | 09:06 AM
  #25
Harleygirl2u's Avatar
Originally Posted by a4annie
I have 2003 A4. Couple weeks back the EPC light and check engine light came on. Shortly after noticed some things happening-once or twice rpms dropped to zero then immediately backup. Then car would just die at a stoplight-would turn over right away. Warning lights would come on intermittently.
Took into Audi service. Put on the computer and it said it was a random error of the speed sensor. Since random, Audi suggested to just clear the error and drive as is. Problem is the dropping in the rpms, the random stalling and now recently after having it in at the dealer, unable to start it at all!!! Finally could after 15 minutes.
I have this feeling it's going to be like they don't know what to do and I don't want to keep plugging money into "maybes" and not getting issue fixed
hi I would check crank shaft sensor..
Bernie O' Brien
Audi Q7
Aug 29, 2012 01:39 PM
jim0475
Nov 11, 2010 09:34 PM
Mike Kucsan
Jan 29, 2009 04:16 PM
MrTigz5254
Mar 7, 2008 11:56 PM
llib
Apr 24, 2006 01:36 AM
