ESP light staying on A4 B6
Subscribe
Feb 14, 2012 | 12:02 PM
So if you stay at park and leave your car in park and dont move will the light still turn on. Or does it turn on once u touch the brake and put it into drive. If the problem only occurs while in drive and if your cruise control is not working and you are getting the esp light i would lean towards the brake light switch. Have you tried to scan your car yet?
Reply
Feb 15, 2012 | 09:36 AM
Quote: So if you stay at park and leave your car in park and dont move will the light still turn on.
No, I don't think so.
Quote: Or does it turn on once u touch the brake and put it into drive.
It typically comes on intermittently while driving.
I have not noticed whether this is due to touching the brake or not.
Quote: If the problem only occurs while in drive and if your cruise control is not working and you are getting the esp light i would lean towards the brake light switch.
Understood.
I think the cruise is not working.
I'll have to test it this weekend.
If it is the brake light switch, how much do they cost, and is that something that I can replace myself?
Quote: Have you tried to scan your car yet?
Not yet. I need to reformat my lappy and purchase a cable.
Do you know which cable is the right one for my A4?
I have an 2005.5 B7 2.0L TFSI.
Thank you for the kind reply. Much appreciated.
Reply
Feb 16, 2012 | 08:35 PM
rear abs sensor
has anyone ever changed a rear abs sensor in a B6 model? I have successfully changed the front abs sensor but the rear abs sensor is completely different. The connection disappears deep inside the car and I am unable to remove the old sensor on that side. Please advise.
Reply
Feb 22, 2012 | 12:24 PM
b6 esp button
what is the esp button? mine dosnt do anything.no lights come on, no change in driving.
Reply
Feb 22, 2012 | 02:15 PM
Understood.
u can replace the brake light switch its very straight forward. As for the cable. gameadvance | eBay
i purchased the blue colored one. If u do go out and buy it and need help installing the drivers pm me and ill see if i can help. only draw back to the blue cable is u cant clear the dtcs. But there is a bluetooth one that will clear the dtcs but wont let u recode stuff.
Reply
Feb 23, 2012 | 09:59 AM
Quote: what is the esp button? mine dosnt do anything.no lights come on, no change in driving.
It's traction control. Electronic stability program
Reply
Feb 23, 2012 | 05:17 PM
Quote: i purchased the blue colored one. If u do go out and buy it and need help installing the drivers pm me and ill see if i can help. only draw back to the blue cable is u cant clear the dtcs. But there is a bluetooth one that will clear the dtcs but wont let u recode stuff.
I ordered this cable:
Amazon.com: OBD2 OBD II Diagnostic USB Cable For KKL409.1 VAG-COM 409: Camera & Photo
Should arrive soon.
I'll let you know when it arrives, and what I find.
What version/flavor of Windows should I install to be compatible with VAG-COM software?
I've heard folks say that it doesn't work on Windows 7 and that the software has trouble recognizing the USB port and that the port needs to be tweaked. Is this correct?
Reply
Feb 23, 2012 | 06:04 PM
  #18
i have windows vista. so it worked like a charm. Basically the ports have to match up from your device manager and through the vagcom program. If u get unrecongnized port just switch your plug to a different usb outlet. Then go in a switch the com port in device manager and vagcom. If u run into any problems pm me and ill walk u through as best i can.
Reply
Feb 24, 2012 | 10:09 AM
  #19
Quote: u can replace the brake light switch its very straight forward. As for the cable. gameadvance | eBay
I have a blue one and it lets me clear codes on my a6. does that only apply to the a4?
Reply
Feb 24, 2012 | 01:14 PM
  #20
hmm ill have to go double check. But last time i tried to clear the codes it wouldnt let me. The only way i know u can is if u purchase the vcds software from rosstech for $99.00.
Reply
