fault failure codes found CCM and others
Old Sep 29, 2010 | 07:16 PM
immusicman's Avatar
Default fault failure codes found CCM and others
Well I put the ross-tech software to use on the audi today and several of the modules reported "No communication" with central convenience module. I plan to get one ordered right away. But I received another fault failure code titled "entry assist, D", and "entry assist, P" which d is driver and p is passenger I assume. The code is 02013 and 02014 which says "switch for seatback latch; passenger seat (f212) 27-00 - implausible signal. The other is the same except it says driver seat. What module would be causing this code? I want to replace all the faulty modules while I am at it so I thought I might ask if anyone could tell me more about the root of the entry codes. thanks.
Old Sep 30, 2010 | 12:35 AM
auditech79's Avatar
what kind of diagnostic are you running? Don't use guided fault finding, interrogate each individual module one by one. The CCM should be designation 46 (35 isn't used on B6's) and any codes read out by the vag com should say which module designation it came from.
Old Sep 30, 2010 | 03:57 PM
immusicman's Avatar
The CCM will not respond. It gives a message saying module not responding. This is VCSD from Ross tech software.
Also, I tried to remove the seat so I can get to the modules and I was able to get front bolts out but seat is too far back and won't come forward. How do I get the seat out if I cannot get to the rear bolts? thanks.
Old Sep 30, 2010 | 05:03 PM
auditech79's Avatar
Well no doubt the CCM won't respond, i was asking what module did you get those fault codes from? Or are those the fault code numbers for no response?
As far as the seat goes, you HAVE to move the seat to get at the other bolts, if the seat won't move you will need to get a 90* angle triple square (like an allan key) to get at those two bolts.
Old Sep 30, 2010 | 08:30 PM
immusicman's Avatar
The codes I listed came from "entry assist D" then "entry assist P" had a similar code. VCSD listed those codes under entry assist module. Where exactly is the ccm on the audi a4 convertible? The worse problem right now is I cannot remove driver seat because the seat is so far back that it is covering the rear bolts. I got front bolts out but cannot get rear out and seat motor will not go forward or backward. It will only recline. ANY help would be greatly appreciated. I hate the idea of going to the dealer..especially when I have VCSD. Thanks.
Old Sep 30, 2010 | 11:52 PM
auditech79's Avatar
Well you don't need to remove the seat to get the CCM module out, you need to remove the door sill holding the carpet down then peel it back to expose the module.
I would try changing that module out before worrying about the seat, that MIGHT make the seat work. If it doesn't you WILL need to go to the dealer to have the seat removed.
Old Oct 1, 2010 | 01:27 AM
immusicman's Avatar
You have helped me more so than any other place I have inquired. Thanks so much. i will do just what you have said to do.
John
dmemisev
Aug 2, 2010 08:42 AM
legendpilot
Dec 20, 2008 08:09 PM
bkraska
Nov 16, 2008 05:13 AM
laserredgt
Sep 25, 2008 12:01 PM
