Finally starting to work on it
Old Feb 27, 2008 | 05:19 PM
auditurbo381's Avatar
Default Finally starting to work on it
i am pulling the car cover off of the B6 since november. the rains have stopped. so i can fix it.........
i will let you know how it looks.
last nov,
shaking, missing, blowing out spark, and then no firing at all.
got some fresh parts. so i will give you an update
Old Feb 27, 2008 | 08:19 PM
Default RE: Finally starting to work on it
ok.... so i think i have an ECU problem. thr car wont even fire. just turns ouver. with the ecu plugged in or out. i just got it back from oliver at speedtuning b4 i covered it for winter. any ideas? i called him and he said he is sure heflashed it correctly.... but would look at it. but thats like 20 bucks in shiping alone. im in cali. any ideas????
Old Feb 27, 2008 | 08:49 PM
audiprotein's Avatar
Your battery??? Did u disconnect it before putting a car in a storage???
Old Feb 27, 2008 | 09:16 PM
yah i did for sure. i have the chrager on it. the car is cranking over fine. just not firing.
Old Feb 29, 2008 | 12:50 AM
kwik_shift's Avatar
I know this is off the subject but how do you like that atp downpipe?you installed it or local shop? and results asfar as being a direct bolt like atp claims?
vtraudt
Jul 24, 2012 03:16 PM
01afour
May 7, 2008 07:39 PM
Floored80Q
Sep 18, 2004 01:52 PM
