Forge 004 DV/BOV
Old Apr 29, 2008 | 12:55 PM
audiprotein's Avatar
Default RE: Forge 004 DV/BOV
^^^ That plug should come with Forge 004 as far as i know. You basically need just to cut the air coming to/from that recir. tube... You can use whatever you want, but the best way is a 1' billet plug, i think AutoZone or Pepboys will have it.
Old Apr 29, 2008 | 01:02 PM
Nick_UltraSport's Avatar
Because the stock DV is connected to the RECIRC. valve when i put my forge004 I have to take it off because the forge doesnt need the recirc valve. Now do I only close it right there where its open or is there two places to i need to close it. Cuz as far as i know i think its only right there by the stock DV and thats it. Thanks again.
Old Apr 29, 2008 | 02:59 PM
auditurbo381's Avatar
the plug does NOT come with the forge 004.
http://www.ecodetuning.com/shop/cart...tail&p=520CLICK THAT. for your plug...
as for your understanding. you are right on the money for the install
Old Apr 29, 2008 | 04:59 PM
I checked auto zone and they dont have it and pepboys eaither do u guys know anywhere else i can check other then the net
Old Apr 29, 2008 | 06:03 PM
click on that link in my previous post... just click it
Old Apr 29, 2008 | 06:06 PM
I dont wanna buy it off of internet I want to know if there is a store that carry's it. I want the internet to be my last choice i know i can find it on internet lol it just i want it now
Old Apr 29, 2008 | 06:16 PM
cincyTT's Avatar
I'm make believe
This is why you order it from ECS since it comes with everything [sm=headbang.gif]
The best you can to is go to Home Depot and find a plug
Old Apr 29, 2008 | 06:17 PM
  #18
that thing is made just for it. so thats the best route if you want to do things the right way. which i suggest on audis.i wouldntcut corners.......
but if you insist..... hardware store. pvc cap. 3/4" or 1" should fit in there just fine.just clamp it down GOOD!
Old Apr 30, 2008 | 09:57 AM
  #19
chaos92287's Avatar
call all the autoparts stores around town. the autozone around here carries the plug
and i just created a thread to show how its installed, since i had my front end off. mine is a b5, but its still gona be done the same way. you stick the BOV in the turbo outlet hose and plug the hole in the TIP. and for you b6 guys, you also remove the useless retarded boost reservoir
https://www.audiforums.com/m_870305/tm.htm
NuYorka103185
May 18, 2011 01:13 PM
vegastt
Sep 4, 2007 12:18 AM
blaznD
Jul 1, 2007 02:26 PM
.clipse
May 15, 2007 11:55 AM
dtmguy
Apr 16, 2007 03:24 PM
