Front brake pad change
Old Jul 15, 2009 | 11:25 PM
jmoneyslick's Avatar
Default Front brake pad change
Pretty much as the title says. I cant figure out how to get the front caliper off to change the pads. any help is appreciated. I cant afford to get the bentley manual right now so im hoping someone here can help.
thanks in adavance guys
jeff
Old Jul 16, 2009 | 10:57 AM
kchao2000's Avatar
This instruction is for B5, but should be the same for B6.
http://www.audizine.com/forum/showthread.php?t=189128
Old Jul 16, 2009 | 09:04 PM
thank you so much for the link. i guess i was doing it right those caliper bolts are just so damn stubborn then. but again, thanks so much for hittin me back with this link
Old Jul 16, 2009 | 09:51 PM
Midniteoyl's Avatar
Hit the treads with ant-seize when reinstalling.
Old Jul 17, 2009 | 03:17 AM
good call thanks for the heads up. does anybody have any tips for getting them off. its a little cramped under there so i cant get the air ratchet under there. ive tried some penetrating oil but no luck. also, whats the best way to jack the car up because i know there are specific jack points but i dont trust that audi tire jack.
Old Jul 17, 2009 | 10:38 AM
Midniteoyl's Avatar
Not to seem like an ***, but are you turning the right way? You are working backwards, so never know.
I wouldn't use the air ratchet, just a good wrench, maybe a breaker bar, and your hands. Its way to easy to screw things up with an air tool.
I jack up using a floor jack at the same points.
Old Jul 17, 2009 | 02:18 PM
haha im pretty certain im turning it the right way, but youre right, you never know. hah ill keep at it see if i can finally get those things to break loose. thanks for all the insight, i appreciate it.
RiverHouse
Jul 11, 2010 07:13 PM
jaymac
Feb 1, 2010 06:24 PM
brrman
Apr 16, 2009 04:26 PM
jaymac
Jul 11, 2008 11:19 AM
joeytattoo
Sep 4, 2004 06:13 AM
