Front turn signal not working!
Old Feb 17, 2012 | 06:57 PM
Phat_J's Avatar
Exclamation Front turn signal not working!
Hey everyone!
So front passenger side turn signal does not light up, and I get an error message on the dash that it's out. The side and rear indicators blink quickly when I use it on that side.
So I figure and easy bulb change would do it, but of course not!
Here's what I have tried so far:
- multiple new bulbs
- swapping the bulb with the for-sure working one on the opposite side
- swapping the holder that contains the bulb with the one on the other side
- scraping at the contacts on the bulb holders as well as in the socket
Still I cannot get that bulb to light up on that side at all.
What else could I possibly try??
And yes I've searched a lot, and people mentioned the hazard relay, however those people have had all their signal lights not working, not just 1 bulb, so I can't imagine it's my relay.
Also someone mentioned checking connectors, wire harnesses, using dielectric grease. Not sure where to spray that stuff, nor where/how to check for wire faults. I'm not familiar with that kind of thing on cars.
Thanks for any insight!
Old Feb 18, 2012 | 09:11 AM
Dozanti's Avatar
The connector grease goes inside the bulb socket, use only a little. I had a vehicle do this once, turned out the previous owner many many years before had used the point of a test light to pierce the wire to test its voltage, water got in it and corroded from the inside. I found the pin hole, opened it up (the wire) and sure enough it was done. Cut the wire there and spliced it and all was well. The point of the story is, there could be a bad spot on the wires leading to the light. Have you tried a test light in the socket to see if you were getting current to the socket?
Old Feb 21, 2012 | 12:10 PM
sburkeatqmi's Avatar
Originally Posted by Phat_J
Hey everyone!
Its the bulb socket. Pull the socket out & pry out the prongs that connect with the bulb. Also use a little sand paper to clean up the contact points.
One way to verify this is to switch the socket with the other side. If the problem follows to the other side its definitely the socket. There's another post in here that explains it. I'll see if I can dig it up.
Old Feb 21, 2012 | 12:11 PM
Oops. Just seen that you tried swapping sockets.
Old Feb 21, 2012 | 12:16 PM
Old Feb 21, 2012 | 12:25 PM
M5S5's Avatar
Tech Certified
Could be a bad flasher , signal switch?
Old Feb 21, 2012 | 01:33 PM
Phat_J's Avatar
By signal switch, are you referring to the hazard relay in middle of the dash board?
Old Feb 21, 2012 | 01:48 PM
M5S5's Avatar
Tech Certified
Yes. Most signal problems on VAG vehicle are usually from that switch being bad.
Old Feb 22, 2012 | 12:24 PM
Dozanti's Avatar
A test light, and multimeter will be your best friend .....
Old Feb 22, 2012 | 12:52 PM
Phat_J's Avatar
Thanks everyone for the replies.
Turns out it was a bad ground causing it.
I just got my mechanic to fix it, as I couldn't be bothered messing with wires and etc myself.
