Fuel Trim
Old Jul 2, 2009 | 09:58 AM
Piperalpha's Avatar
Default Fuel Trim
Hi All,
My Audi A4 B6 2002-2003 (70,000 miles) has a Check engine light on.
I used PCMSCAN to get the OB2 code and it says the fuel trim is too low. If I clear the code, it will come back in about 100 miles.
K, I get that this could be a problem with the MAF or a vacume leak.
I got some MAF cleaner and sprayed the hell out of it. (If this does not work, I will look for vacume leaks)
Now, do I need to clear the CEL and then wait to see if the light comes back on? OR do I not clear it and wait to see if it goes off?
Any help is appriciated! (It drives me crazy...)
Cheers
Piper
Old Jul 2, 2009 | 01:04 PM
Mike-2ptzero's Avatar
Need to clear the code each time since clearing the codes also resets the fuel trim adjustments.
Old Jul 3, 2009 | 02:25 PM
Piperalpha's Avatar
Default Fuel trim resolved
Thanks for the info which probably would have worked too, however, I left the code on and it cleared itself after about 40 miles or 4 trips.
I strongly advise anybody with a fuel trim problem to buy a can of MAF cleaner (About $3) and spray the hell out of the MAF - leave to dry before starting.
I'm so pleased that this was a $3 fix instead of hundreds!
Thak you forum (Learnt the info from searching) - made my day!
Cheers
Piper
Old Jul 3, 2009 | 06:16 PM
auditech79's Avatar
Your name's Piper? Thats awesome!
andrewj654321
Nov 19, 2008 09:53 PM
waveblaster200
Sep 26, 2008 03:04 PM
cparke
Aug 22, 2008 11:52 PM
rockfreek05
Mar 31, 2008 01:11 PM
onepoint8tee
Aug 19, 2006 05:34 PM
