further examination
Old Oct 22, 2025 | 02:23 PM
jameder92's Avatar
Default further examination
Hi all,
So my car filled up with water, and I pulled the driver's seat so I could pull up the carpet and dry things out. I temporarily put it back in to go somewhere, and noticed the rails were out of alignment. Upon further examination, it seems that one side is off relative to the other, so I extended the seat all the way forward to line everything up. Perfect! Except now it's stuck! One side will go back, but the center console side won't move. Looking under the seat, I see that the horizontal motor has fallen loose. It still spins, but it's not engaging the worm gear. Any ideas here? Obviously, I can't remove the seat any more because it's covering one bolt. The motor that has fallen loose has left a black plastic bracket in place, but I'm not sure even getting it to fit back in will work.
By the way, since I'm here, how do you get the CCM out of the protective box!Thanks in advance!
Baldwyn
jameder92
Oct 10, 2025 12:38 PM
jameder92
Oct 9, 2025 11:43 AM
Rob Strongin
B7 Models
Oct 16, 2020 03:16 PM
