got quote from audi... what needs immediate attention?
ok so i got my quote from audi today... 3 leaks, 1 oil and 2 tranny... on all 3 the seals need replaced. i found a shop to do it for cheaper than audi but im tight on cash so what really needs immediate attention?
here is the quote:
here is the quote:
yes you are right it is sealed... not saying im going to do this, but theoretically how long could i go with the oil leak if i were to just keep topping it off... basically what im saying is if i wait a month or 2 until i fix it with just topping the oil off would i be ok?
Is this a Tiptronic or manual transmission?
At any rate, the transmission leaks should be repaired first. The engine oil leaks are common on the A4, and the only thing those are going do is give you a burning oil smell in the cabin eventually. That can wait until you're better off financially.
The tiptronic transmission is not sealed, per se. But to fill it with fluid does require that you do so from underneath the car via a 17mm hex fill hole. There are some DIY's around that you can google if you want to try it yourself.
+1 to the above comments. Get the tranny done as soon as you can since that will turn into a much more costly problem if it gets too low on fluid.
You can add oil for a while and not hurt anything. With your mileage I would say wait for the cam/tensioner/valve cover seals to be done when you do the first timing belt mainenance.
Automotive Dezignz
Mar 7, 2009 07:05 PM
