Having hid issues
Old Nov 1, 2012 | 05:02 PM
tofast2belast's Avatar
Default Having hid issues
Hi I installed hid kit and I am having issues with bow. I did the relay harness and still having issue
Any help?
http://imageshack.us/a/img267/7228/imagetrhn.jpg
Old Nov 2, 2012 | 07:07 AM
anyone?
Old Nov 2, 2012 | 03:55 PM
Dozanti's Avatar
Your ECU can see the resistance values across the bulbs are not what they should be according to factory set value. I have read about this but mostly for the l.e.d lights and the fix is adding a resistor in the line. I'm not 100% about the HID fix. The lights work correctly, you're just getting the warning for a "bulb out" correct?
Old Nov 3, 2012 | 07:24 AM
well before i had it hooked up to the stock headlight harness with capacitor. i was getting the BOW if the ballast wouldnt start. i was also getting esp light occasionally and when turning headlight on it would also reset the climate control, like it would turn off and on. this is why i did the relay harness but still getting a BOW now all the time.
Old Nov 5, 2012 | 06:27 PM
pa4ul's Avatar
bow? What is this?
Old Nov 8, 2012 | 07:49 AM
Originally Posted by pa4ul
bow? What is this?
Bulb Out Warning light
Old Nov 8, 2012 | 12:21 PM
pa4ul's Avatar
wow i never heard it referred to as bow. . . Either way u make sure all your connections are snug. your light does not flicker or anything does it? HAve u tried sticking regular bulbs in to verify its the hids causing this problems? I would do that first and see if the problem disappears. Also what kit did you buy? Dont tell me it was off of ebay????
Old Mar 6, 2013 | 08:43 PM
Marine702's Avatar
I had the situation when I installed my HIDs in the headlights. I had to buy a set of canbus Canceler modules. I purchased my HID kit from HID Kit, HID Conversion Kit, HID Headlight Kit for Cars & Trucks at HIDNation.com
I was getting an ABS, BRAKE AND ESP light turning and speedometer wouldnt work. Or just the ESP light on. Take a look at the site
Old Mar 7, 2013 | 01:09 PM
pa4ul's Avatar
hey already purchased a relay harness and it still is causing problems.
Old Mar 8, 2013 | 06:40 AM
i finally went back to oem couldn't stand the beep any longer :-/
