Headlight chime not working
Old Jan 23, 2015 | 05:50 PM
Regarp's Avatar
Question What did you find?
I'm having the same problem, bad beep speaker. I'm curious if you found the problem? Mine is a 2005 A4. If it was the beep speaker, as you and I suspect, is it accessible?
Old Apr 25, 2015 | 03:35 PM
audi_andover's Avatar
Default headlight chime
I have a B7 A4 and was told by the dealer the cost to fix this would be 1000 dollars. Electrical gremlins...
Is there a DIY solution?
Old Nov 16, 2020 | 09:43 AM
Chris76's Avatar
door lock assembly is the problem. The contact switch inside the door lock has failed. Since it is a complete unit, the only way to correct this is to replace the left door lock assembly. This is a very common issue with both VW and Audi.
Old Nov 16, 2020 | 09:55 AM
Thanks, Chris. Do you have a link to a DIY to how to replace the left door latch assembly?
Old Nov 16, 2020 | 10:33 AM
Chris76's Avatar
Apologies I meant the drivers door assembly, i found it on an American site. I don't have instructions sorry
Old May 27, 2022 | 01:22 PM
Taiwan's Avatar
It looks no one has solve the problem with detail explanation.
I think it’s the bad beep speaker at the back of the instrument cluster, but not able to have anyone to confirm it so far.
Old Nov 30, 2023 | 01:08 PM
PierceSchuman's Avatar
Try to work on it and could not get any progress on it..
jerehege
Sep 16, 2013 12:28 AM
xster
Dec 17, 2008 02:02 AM
andrew.bator
Oct 27, 2008 01:42 PM
needhelpinNY
Aug 31, 2007 12:32 AM
Karl
Jan 8, 2006 03:29 PM
