Headlight help
Old Oct 13, 2010 | 02:00 PM
seal66's Avatar
Default Headlight help
I did some searching on here before I became a member on the forums. My buddy has a 2004 A4 Quattro, that came with the auto leveling HID headlights. We ordered up new HID kits for the lights. My question is does anyone have install help with pictures. I noticed that the H7 bulb fits very loosely in the socket and the spring does not hold it down at all. Also for the D1R's, how do you bypass the stock system to control the headlight. The wiring kit that was sent with the HID only had 4 short connecting wires in it. We also order up HID fog kits as well.
Everything came from VVME which I use for Jeeps all the time. I am used to single lamp non HID setups so. Thanks for the help guys/gals
Old Oct 14, 2010 | 01:43 PM
seal66's Avatar
well a lot of info in here
no one has an answer uh?
Old Dec 6, 2010 | 01:10 PM
32_d3gr33s's Avatar
what kit did you get? i see they have 35 or 55 watt. they also have 8-16 volt input or 18-26 volt input and im not sure what to get. did you get them put in? any update would be awesome!
Old Dec 8, 2010 | 07:06 PM
seal66's Avatar
The car has stock HID's already. VVME said there kit would work in the stock Headlight housings. But so far we have not been able to. We did get the high beam HID kit in with no problems at all. Also well have the FOG light HID kit in as well.
I don't know they voltage I ordered what there kit fit guide said to.
Jrmiller
Feb 25, 2013 03:03 PM
Influentialstylez
Mar 29, 2007 04:30 AM
rkohan
Mar 20, 2007 04:16 AM
