Headlights come on when braking (random)
Old 05-22-2019, 07:12 PM
wmccann's Avatar
Default Headlights come on when braking (random)
Weird problem. A4 B6 Cab highline.
Often when I brake I get an error in the dash regarding the auto lights sensor and the main headlights come on (can be a quick flash of the headlights or for as long as I keep the brake pedal pressed).
VCDS shows error that there is no signal from light sensor - intermittent.
Other symptoms include:
  • Coming home light and auto light leds on light selector flicker at high rate (while brake pedal is pressed)
  • Power to centre rearview mirror is lost (compass switches off)
  • Have noise (static hiss) from speakers that goes away when brake pressed
Have replaced the power control module and the rearview mirror and all rear bulbs (apart from high brake light) and the brake pedal switch as well as checked the wiring.
Since replacing the rear view mirror it happens approx 30% of the time. With the old mirror it was happening 90% of the time. Also with new mirror when it happens it just flickers with the old sometimes it stayed on as long as the brake pedsl was depressed.
Btw, it only happens if light selector is in the off or in the auto position.
Finally (though could be unrelated) sometimes the horn sounds weak/"off tone".
Any ideas appreciated.
W.
JoePatch
02-03-2015 09:40 AM
mikeshere443
12-25-2008 10:03 PM
wootang71
05-03-2008 11:24 PM
ccomengee86
10-02-2007 09:27 AM
karageorge2
10-11-2005 12:41 AM
Quick Reply: Headlights come on when braking (random)
