help with brake lights problem.
Old Dec 13, 2008 | 07:28 PM
mikeshere443's Avatar
Default help with brake lights problem.
hey everyone i have a 95 audi a6. during the day the brake lights work fine and turn on and off normally but when the headlights are on the brake lights do not turn off anyone know what this could be???
Old Dec 15, 2008 | 12:44 PM
NH_USA's Avatar
I'd begin looking fo a short circuit --do the headlights go on with the brake lights during the day?
Old Dec 15, 2008 | 10:01 PM
a6hcw's Avatar
Try unplugging the brake light switch at the brake pedal, then turn on your headlights. The brake lights should not go on without the wires connected to the brake light switch. When the brake pedal is against the switch, the contacts are open. When you push the pedal down the contacts close, which turns on the brake lights.
On the 1996 Audi A6 Quattro I have, the brake light switch has four pins. The two large pins are for the brake light circuit. The two small pins may go to the transmission control unit.
You may have a short circuit between your head light circuit and you brake light circuit.
Old Dec 25, 2008 | 10:03 PM
no the headlights stay off during the day when i hit the brakes and when i unplug the switch and turn on the headlights the brakelights will still turn on. also while driving with the headlights on the brake light in the cluster will turn on then back off occasionally
jpcallmotor
Jul 14, 2010 10:00 AM
pezster
Oct 30, 2008 11:37 PM
tophubufu
Sep 5, 2008 08:19 AM
m5systems
Dec 19, 2006 06:30 AM
cbing28
Mar 19, 2006 01:33 PM
