heat problem
hi everyone!
I just bought a 2002 audi 1.8 t with rough running engine I ended up changing the engine because it turned out that i had no compression in two cylinders but more about the engine after openinig up, the problem now that I do not have sufficent heat ( at idle no heat, at cruise no sufficient heat to heat up the car ) the gauge is showing operating temperature in about 4-5 minutes. I tried to bleed the engine with the front jacked up at the hose that comes out from the core heater . At 2-3000 rpm initially i heard air coming out from the hose than I let it idle and the flow nothing came out from the hose. I tried the repeat the process but no luck .
I also would liked to remove the climate control unit.Anybody could help me?
