Heater problems.
Old Nov 10, 2012 | 10:57 AM
wightoriginal's Avatar
Default Heater problems.
When i put on the blower in the car , it only blows warm air on the drivers side. The passenger side is constantly cold. I have checked the fuses , taken the glovebox out to check if the pipes are off.
It is a 2005 2.0 tdi.
Thank you in advance.
Old Nov 12, 2012 | 12:24 PM
pa4ul's Avatar
i hate to ask this but i feel i must. ARe you sure the drivers side temp is following the passenger side temp?
Old Nov 13, 2012 | 02:44 PM
Yes it is. In fact ive even put the drivers right down to low and put passengers up to high to see if that would work but no difference.
Old Nov 20, 2012 | 12:38 AM
sick_vdub's Avatar
Might be a flapper motor, scan the climate control for codes, if no codes, check try to see if the motor turns anything or its just making noise... Ive see the gears get chewd up in them and they would not throw any codes and sound like they work, but not...
Old Nov 20, 2012 | 04:50 PM
ECS Tuning's Avatar
Sponsor
Seams like the blend door is malfunctioning. It could be a servo that's bad and not opening the door to mix hot n cold air.
Unfortunately it probably wont be the easiest to access - might be something the dealer would be better of doing.
Jason
Old Nov 26, 2012 | 05:40 AM
Dan1969's Avatar
2nd on that blend door. I think you have some of those in your store anyways right ECS?
Old Nov 26, 2012 | 10:48 AM
ECS Tuning's Avatar
Sponsor
I would have to dig up the part number but yes it is available through our site.
Jason
huntingpastor
Jan 2, 2015 04:29 PM
madmatuk
May 16, 2013 11:10 AM
SloRide
Nov 30, 2009 10:17 AM
pete7
Jan 21, 2006 02:04 PM
pete7
Jan 17, 2006 03:52 PM
