heating issue
Old Sep 10, 2009 | 08:24 PM
timmay074's Avatar
Default heating issue
so heres my new deal
i decided to turn the temp up on my climate control cause it was a little chilly, i set it to 75 and cool air was still coming out of the foot vents (mind you it was 59 degrees outside)
i now tried to put the temp. up to HI and put it on the main vents to see if i feel the heat, still nothing. it isnt as cold as if it were on LO but it's luke warm feeling as maximum heat will not feel good in my new england winter. =(
i also did these tests after driving for about twenty mins so the engine is at temp.
any suggestions at all?
Thanks,
Tim
Old Sep 10, 2009 | 10:36 PM
shane.trammell's Avatar
if theres orange gunk on the pass. side of the bellhousing its your coolant flange. thats the most likely culprit. is the coolant full? you could try bleeding that next.
Old Sep 11, 2009 | 05:02 PM
timmay074's Avatar
i havnet gotten around to checking anything today since its raining, but, if it is the coolant flange, can i expect any other problems or is this one thing that i can leave alone for the time being?
i am a mechanical noob so bare with me guys =P
Old Sep 11, 2009 | 06:40 PM
Not really any other probs except running out of coolant and overheating.
I will take this opportunity to say be sure to only use g12 coolant which can pretty much only be gotten from vw/Audi.
Old Sep 11, 2009 | 08:03 PM
timmay074's Avatar
well, i checked the coolant today, and it seemed rather full, and ive had this car for 3 months by now and it has not overheated, its been at the halfway mark forever and i did minor investigating under the hood, and i did not see orange stuff around so im not sure now
thanks for the help though
Old Sep 11, 2009 | 09:25 PM
dunanga's Avatar
Default Warm air on Hi setting
There are two possible culprits:
1: Your thermostat is kaput (stuck in one position)
and / or
2: coolant temperature sensor is not sending a correct signal
****You might notice that your temperature gauge only kisses 90 when you are stuck in traffic and just above 50 when cruising. Good luck!
Old Sep 11, 2009 | 09:33 PM
S_R_N83's Avatar
Clogged Heater Core?
Old Sep 11, 2009 | 11:18 PM
The heater core is possible but less likely. The coolant sensor is common, but is kind of a pain to change out.
rocktbone
Sep 28, 2012 05:46 PM
irishaudi
Sep 14, 2010 12:34 PM
salating
Feb 11, 2009 12:36 AM
Matori1.8Tq
Jan 2, 2009 05:20 PM
mrdb85
Aug 12, 2008 01:28 AM
