Help...2002 A4 Timing belt change...now in process
Old Feb 6, 2010 | 04:14 PM
mjfrizz's Avatar
Default Help...2002 A4 Timing belt change...now in process
I am in the middle of a TB change, and I am stuck at the accessory belt pulley that comes off the crank. Are the four socket-heads around the crank bolt hole all that hold the pulley on? I took those four off and I can't get the pulley off...they they stick often? Or do I have to remove the crank bolt to get the pulley off. I thought I didn't need to remove the crank bolt unless I was changing seals..I already looked at all the tech articles and everyone says they just took the bolts off and they the pulley comes off...what is a good way of breaking this guy free?
Old Feb 6, 2010 | 10:19 PM
mjfrizz's Avatar
Default nevermind
Obviously a gear puller works nicely
Old Feb 7, 2010 | 01:26 AM
sean1.8t's Avatar
that pulley seizes a bit. just tap it with a hammer a few times and it'll break free
aTiTude
Mar 22, 2013 04:23 AM
chris
Apr 22, 2009 11:44 AM
sdboarder84
Dec 17, 2007 04:36 PM
mrtel
Jun 29, 2007 06:53 PM
