Help!! Crackling type sound!!
Old Dec 16, 2010 | 11:43 AM
Leadfoot'er's Avatar
Originally Posted by ppgoal
Maybe silicone spray the snot out of your front bushings?? (Don't use WD40.) Rubber could be shrinking in the cold and when the metal moves, they squeal. Also, air bubbles in the P/S fluid may cause noise. I read on the A6 forum to jack up the car and slowly turn lock-to-lock 6-8 times.
I'll try that,It may very well be the bushings because the sounds goes away once I drive it for awhile(I guess as it heats up)..Thanks..
Old Dec 16, 2010 | 12:54 PM
shane.trammell's Avatar
Im guessing bushings as well. It was in the 70s yesterday and no noise.
Old Dec 16, 2010 | 04:58 PM
adidamac's Avatar
Exclamation
Originally Posted by Leadfoot'er
I checked the fluid that day and it seems to be fine..It's not the "remote control car" sound,it's more like a door w/rusty hinges creeping opening but not quite(it really is hard to describe)..
I will check that pipe thats in front of the radiator though..Someone said it could be the bearings but idk if that would be it..
Dear God I was just gonna post about this problem...the EXACT thing! its not a whine as if the steering is strained....when you turn the wheel (especially in stand still) it sounds not like door creaking but as if you are inside a submarine in a movie where it is about to break and water leak and all the dramatic stuff
the sound is more structural I'm so **** scared i feel my car is gonna break apart....and yes its definitely gotten worse in the cold weather...
Here's something I don't know if you guys noticed....say you turn the wheel left for example and you hear the creaking groaning sound....straighten the wheel and then if you turn it left again the creaking sound is not really there...so if you keep turning it in the same direction the sound won't come...but the moment you turn it right that creaking is back!....and same thing you keep turning right it will not come but the moment you turn left again it will creak
I want to sort this out ASAP....its scaring the hell out of me (specially cuz my car has a carfax history of structural damage).
Old Dec 17, 2010 | 03:19 AM
adidamac's Avatar
Sorry I know its over dramatic i freaked...i've been reading it seems the control arm bushes need to be replaced at around these many miles...not sure
Old Dec 17, 2010 | 07:33 PM
LOL the submarine sound is kind of spot on..But don't worry I freaked a bit,never heard it before..But yeah I think the bushings are the major problem,you may have read but I was told to spray it..As for the wheel thing,I didn't notice that..I'll see if it happens next time I get in the car..
Old Dec 18, 2010 | 10:52 AM
adidamac's Avatar
Yeah I read about the spraying thing....but did it work for you? If so then i'll do that...
I'm gonna post on a seperate thread about this...but last night I noticed white smoke from my exhaust...kind of faint not really there and it felt like the vapor you get when you start the car...problem is that its there when the engine has warmed and has been driven....it does not smell sweet (which would have meant anti-freeze) and it did not smell oily...don't really know what it was...maybe vapory....but does the water vapor still come from the exhaust after its been driven a while?
Old Dec 18, 2010 | 06:06 PM
Haven't tried it yet but will soon..As for the smoke i'm not sure,is it still cold or cool where you are? If so it may just be the heat from the exhaust against the cold air..Not sure though..You should try sea foaming your car after you find what the problem is..
Old Dec 20, 2010 | 10:29 AM
  #18
ppgoal's Avatar
Light condensation is normal. I drove 75 miles yesterday (at 70-90 mph, so I know the engine was well warmed up) in 25o weather and when I stopped for gas (engine running), I noticed it still emitted light "smoke".
3dviz
Jul 15, 2013 10:39 AM
FixOrRepairDaily
Jun 26, 2008 10:49 AM
RollinA4
Sep 24, 2006 11:49 AM
quattromond
Aug 1, 2006 07:58 PM
A4speed
Feb 19, 2006 05:57 AM
