Help Please ... 1.8T Coolant Leak Right Side (Passenger Side)
Hi Everyone,
I'm trying to figure out where coolant is leaking from on my 2004 A4 1.8T FWD.
I thought it was the coolant flange, so I had that replaced, but the leak continues.
Coolant is leaking somewhere along the right side (passenger side near turbo & exhaust). It leaks slowly (it takes about a month for the coolant level to drop below the MIN mark on the overflow tank).
I can see buildup of cooked coolant at the back right side of the engine.
What, other than the coolant flange, could be causing this leak? Is there a sensor on that side of the engine, or maybe the coolant line for the turbo?
Thanks,
Chris
Thanks,
Chris
Its either the flange or the turbo. Given the location of the dried up coolant it has to be the flange. Who replaced it? Its VERY easy to pinch the O-ring from the flange to cylinder head upon installation (i've done this more than once) and it could still be leaking from that area.
I had the dealer replace the coolant flange, so maybe the turbo I guess. I'm going to do the "SAI Delete" on my car, so, hopefully that'll give me enough room to look around down there and see what's going on.
Chris
Chris
Yes because the DEALER never ***** up, my money is still on the flange.
Thought I'd update everyone now that I got this fixed.
The smoke turned out to be caused by the Cam Tensioner half moon seal. I replaced this myself using the great DIY at http://www.audizine.com/forum/showth...et-replacement
This leaking seal was causing oil to drip down onto the CAT causing the smoke.
I best deal I found on the gasket set was at BlauParts.com and they rent you the Cam Tensioner compressor tool for $10.
Thanks for everyone's help on this.
Chris
Chris
I kinda have the same problem, the past 2 days its been leaking coolant when car seats for a longer time. So yesterday when i got back from work i lift the car up and went under it, i did not see any thing so i turn the car on to see with pressure still nothing dripping so i though it have to much coolant on. So i go to work today and park the car in garage and after 4 hours i go to check it had happen the same thing so im still trying to figure out where is coming from but don't no where.
kbon
Dec 21, 2014 08:44 PM
mr_indomitable
Apr 23, 2009 11:06 PM
