Help Please ... 1.8T Coolant Leak Right Side (Passenger Side)
Old Jan 26, 2011 | 09:42 AM
chawkinson's Avatar
Default Help Please ... 1.8T Coolant Leak Right Side (Passenger Side)
Hi Everyone,
I'm trying to figure out where coolant is leaking from on my 2004 A4 1.8T FWD.
I thought it was the coolant flange, so I had that replaced, but the leak continues.
Coolant is leaking somewhere along the right side (passenger side near turbo & exhaust). It leaks slowly (it takes about a month for the coolant level to drop below the MIN mark on the overflow tank).
I can see buildup of cooked coolant at the back right side of the engine.
What, other than the coolant flange, could be causing this leak? Is there a sensor on that side of the engine, or maybe the coolant line for the turbo?
Thanks,
Chris
Old Jan 26, 2011 | 09:13 PM
auditech79's Avatar
Its either the flange or the turbo. Given the location of the dried up coolant it has to be the flange. Who replaced it? Its VERY easy to pinch the O-ring from the flange to cylinder head upon installation (i've done this more than once) and it could still be leaking from that area.
Old Jan 28, 2011 | 10:12 AM
chawkinson's Avatar
I had the dealer replace the coolant flange, so maybe the turbo I guess. I'm going to do the "SAI Delete" on my car, so, hopefully that'll give me enough room to look around down there and see what's going on.
Chris
Old Jan 28, 2011 | 11:36 AM
pa4ul's Avatar
sai delete:?
Old Jan 28, 2011 | 06:21 PM
auditech79's Avatar
Chris
Yes because the DEALER never ***** up, my money is still on the flange.
Old Jan 28, 2011 | 06:23 PM
auditech79's Avatar
Originally Posted by pa4ul
sai delete:?
Secondary Air Injection
Old Mar 27, 2011 | 02:38 PM
chawkinson's Avatar
Thought I'd update everyone now that I got this fixed.
The smoke turned out to be caused by the Cam Tensioner half moon seal. I replaced this myself using the great DIY at http://www.audizine.com/forum/showth...et-replacement
This leaking seal was causing oil to drip down onto the CAT causing the smoke.
I best deal I found on the gasket set was at BlauParts.com and they rent you the Cam Tensioner compressor tool for $10.
Thanks for everyone's help on this.
Chris
Old Mar 27, 2011 | 05:47 PM
BesI's Avatar
Default Help!
I kinda have the same problem, the past 2 days its been leaking coolant when car seats for a longer time. So yesterday when i got back from work i lift the car up and went under it, i did not see any thing so i turn the car on to see with pressure still nothing dripping so i though it have to much coolant on. So i go to work today and park the car in garage and after 4 hours i go to check it had happen the same thing so im still trying to figure out where is coming from but don't no where.
Old Apr 28, 2017 | 07:49 PM
breezy_60's Avatar
I have white smoke coolant coming threw my vent coolant leaking underneath car what could it be
kduznetsov
Aug 24, 2011 03:11 PM
vtraudt
Oct 25, 2010 02:46 PM
mr_indomitable
Apr 23, 2009 11:06 PM
Spoke
Dec 3, 2007 09:45 AM
