Help please. Timing belt replacement now no power steering
Old Mar 10, 2014 | 10:51 AM
brave1's Avatar
Default Help please. Timing belt replacement now no power steering
Just had my timing belt replaced by a local shop. Picked it up and it had no power steering. I just recently purchased the car and it seemed to be working fine before. Hadn't heard any noises or anything. The shop is saying it is the pump but I'm not sure if it something they did or did not do. They said they replaced everything except the serpentine belt because it looked new, had to replace the accessory belt because it "blew up", and replaced a power steering hose that broke. They found a piece of the old PS hose in the actuator which they thought originally was causing the problem. I put the front up and tried to bleed it but had no success.
Any thoughts or suggestions are greatly appreciated. Thanks!
Old Mar 10, 2014 | 08:42 PM
JDJ's Avatar
JDJ
While in the shop for my last timing belt change, the power steering pump on my 02 A4 3.0 died. The mechanic bled the system several times hoping the problem was air in the system, but it turned out to be the pump. Maybe some stress is placed on the pump during the timing belt change, I don't know. This was the original pump on my car, and the odometer was at 225k at the time, so I assumed it was a case of the pump's time being up.
hiway006
Apr 18, 2015 01:11 PM
Timon
Jul 7, 2012 01:29 AM
RedShoeRider
Sep 14, 2009 03:02 AM
sandnsnow24
Jul 3, 2005 01:24 AM
