Help on replacing my A4 B6 Foglight bulbs
Old 01-28-2012, 11:01 AM
rlquattro2003's Avatar
Default Help on replacing my A4 B6 Foglight bulbs
Need help on replacing my A4 B6 Foglight Bulb, was able to pull it outbut not enough to remove the connectors? is it necessary to remove the entire bumper to do this? please help and would be very helpful if there are photos
Old 01-28-2012, 06:34 PM
spikezone2004's Avatar
sometimes the cables will get caught on the bumper, i took my foglights out couple days ago to put hids in and i had the same problem, make sure the 2 torx screws are out and then pull it to the side because theres two bits that go through holes on the other side of the torx screws that hold it in place aswell
Old 01-29-2012, 12:43 PM
thanks, meaning the torx screw should be completely removed and the washers should be removed because its holding the cables? ill try it thanks.
Old 01-29-2012, 02:15 PM
the washers? there shouldnt be any washers too remove. post a pic of your fog light housing
Old 01-30-2012, 01:49 PM
pa4ul's Avatar
by washers could he possibly mean the green tabs? nice look spike! U said the lowers are 8000k or 6000k?
Old 01-31-2012, 02:16 AM
Thanks man. The lowers are 8k and the headlights are 6k
Old 01-31-2012, 07:00 PM
thanks guys, was able to pull it out already
LilRobb
08-29-2008 11:29 PM
93Akkord
11-29-2007 01:42 PM
a4nate3.0
07-06-2007 05:56 PM
Belligerenceā„¢
05-01-2007 12:21 PM
jarocho77
05-22-2006 12:24 PM
Quick Reply: Help on replacing my A4 B6 Foglight bulbs
