HID Fog Lights Need Help
Old Apr 11, 2010 | 11:39 AM
mikeeace's Avatar
Member
Default HID Fog Lights Need Help
I have a 2005 3.0 A4. Im looking to get HID fog lights, but im unsure if i should get 35,or 55 watt. Also What range do you guys think i should get 3000k-1200K. (Thats the Color) I want to be able to match my headlight but idk what to pick. Could use some help and advice.
If anyone has done this before do i need a power adapter or a harness?
Thank you
The site is http://www.ddmtuning.com/index.php?p...d=101&parent=0
Old Apr 11, 2010 | 01:04 PM
Dan1969's Avatar
I'd go for the 35 watt, 55 watt is to potent and will probably be as much as the headlights. The spectrum on the headlights is 4300K, I have not done this install so I don't know what you might need.
Old Apr 12, 2010 | 12:07 PM
pa4ul's Avatar
i assume u have stock hid's? If so the kelvin output is 4300k like dan states. and recommended 35 watt as increasing wattage will for one potentially burn ur housing and two will lose the color of light and turn into a more white color then ur stock hids. Installing is no biggie. just snap out the grills surrounding the fogs use ur torx bit to remove the fog housing. Install bulb and ballast. and make sure to mount in a safe location away from elements. Also best place to order is ddm tuning. Any other questions feel free to ask.
Old Apr 12, 2010 | 04:11 PM
scskim's Avatar
Another brand is vvme.com
Got mine through them and havent had problems for 2 years now
Old Apr 13, 2010 | 12:12 AM
mikeeace's Avatar
Member
Thank alot guys now do i need a power adapter or anythign do you know??? or just the plug and play ballast? the people on the site arent very helpfull and its an H 11 bulb right?
Old Apr 13, 2010 | 12:00 PM
pa4ul's Avatar
h11 plug and play. everything is included in the kit from ddm. I cant speak for vvme though.
Old Dec 6, 2010 | 01:14 PM
32_d3gr33s's Avatar
any updates? Im looking at getting some but want to make sure they work. Waht input voltage did you get? i see there is a 8-16 volt or a 18-26 volt. I want to make sure to buy the right one...
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
