HID Fog Lights Need Help
I have a 2005 3.0 A4. Im looking to get HID fog lights, but im unsure if i should get 35,or 55 watt. Also What range do you guys think i should get 3000k-1200K. (Thats the Color) I want to be able to match my headlight but idk what to pick. Could use some help and advice.
If anyone has done this before do i need a power adapter or a harness?
Thank you
The site is http://www.ddmtuning.com/index.php?p...d=101&parent=0
Thank you
i assume u have stock hid's? If so the kelvin output is 4300k like dan states. and recommended 35 watt as increasing wattage will for one potentially burn ur housing and two will lose the color of light and turn into a more white color then ur stock hids. Installing is no biggie. just snap out the grills surrounding the fogs use ur torx bit to remove the fog housing. Install bulb and ballast. and make sure to mount in a safe location away from elements. Also best place to order is ddm tuning. Any other questions feel free to ask.
nize
Jun 21, 2013 01:16 PM
L_U_D_I_AAudi
Jun 3, 2012 04:09 PM
mypreludeisred
Aug 9, 2006 11:08 PM
lilman05
Apr 27, 2006 02:56 AM
lilman05
Apr 25, 2006 10:04 PM
