High-pitched whining sounds at engine start and when driving
Old Jul 12, 2010 | 11:28 AM
joncowden's Avatar
Any noise from the back, especially a shifting noise when accelerating/decel... points to fuel pumping.. I just had this.. ONCE YOU START HEARING THE NOISE, it is time to change the filter. The noise is comming from a clogged filter causing the pump to work harder.. Also, to my understanding, there are 2 filters, on external and one internal to the tank. The external is on the outside right next to the tank, in the middle of the passanger side.
It is expensive if you go to a dealership. The one here in St Louis wanted $1100, the Midas wanted $860.. I had my Audi guy (30+ year retiree from Audi Service Dept) get a fuel pump for 230(oem) and filter for $45 and install them for $100.... It is work at a medium difficulty. There is a place in the trunk that gives you easier access to the fuel pump, which is in the fuel tank. You have to remove the spare cover in the trunk in on the upper-right of the spare compartment, there is a removable plate that once removed, will give you access to the fuel pump. I watched on how to do this so I can do it next time....
Old Jul 13, 2010 | 09:04 AM
Swear1's Avatar
Thanks for the information JonCowden,
But hopefully there won't be a next time!
Audi dealer is planning to check mine out this week.
tspiv
Jan 19, 2011 11:45 AM
parlayin
Jun 10, 2010 02:13 AM
satishtadi
Oct 29, 2006 11:25 PM
juice88
Oct 26, 2006 05:12 AM
FLEX_rs
Oct 25, 2006 10:30 PM
