Hood Latch Sensor Location??
Old Apr 5, 2013 | 08:29 AM
gschleg84's Avatar
Default Hood Latch Sensor Location??
I got in my car last week and the dash said my hood was open. I got out and and checked to make sure it was latched which it was. Has anyone had a problem with the sensor being faulty? If so where is it located and is it easy to replace?
The bigger issue is now my alarm goes off randomly throughout the day becuase the alarm system thinks the hood is open when it is actually not.
2002 A4 1.8T
Thanks for any help.
Greg
Old Jul 19, 2014 | 06:27 PM
Emanu's Avatar
The exact same thing is happening with my car, did you ever get a response on how to get it fixed?
Old Jul 23, 2014 | 06:51 PM
DanSoCalMan's Avatar
It is a micro switch under the hood latch. With a light you can see the wires coming up between the fans and going to a switch on the left side of the latch. When the switch is closed (your hood is closed) the signal to the alarm is open and when the switch is open (hood opened) the signal to the switch is closed.
I was having trouble with mine, and I cut the wires to the switch. At first I twisted the wires together but the warning light stayed on. That's when I discovered it needed to NOT be touching together. So now the wires are just taped together, with not bare wire showing and not touching and all is well.
Old Dec 30, 2015 | 05:36 PM
bull852003's Avatar
thanks. very helpful
Volcar
Nov 13, 2014 02:12 PM
pyropenguin
Sep 9, 2011 10:06 AM
muurai
Dec 25, 2010 05:16 AM
rummy
Jan 25, 2009 10:02 PM
jzmuda
Apr 7, 2008 10:09 PM
