How to reset ecu
Old Mar 17, 2009 | 03:25 PM
peter121's Avatar
Default How to reset ecu
I have an 03 A4 1.8 quattro and the brake light out is on and it is working fine. I have scanned the ecu with no problems found. Doe anyone have any suggestions.
Thanks
Old Mar 17, 2009 | 07:23 PM
pa4ul's Avatar
unplug that battery for 10 mins
Old Jun 23, 2009 | 03:17 AM
copper07's Avatar
Did disconnecting the battery solve your problem?
Old Mar 13, 2012 | 01:33 PM
jinsojoo's Avatar
Default Brake Light Failure Warning - Voltage Difference?
Just a though - perhaps you replaced a brake light that indicates a slightly different voltage potential which is causing the brake light failure warning lamp to light up? This has happened to me before.
You might want to try replacing the bulbs on both sides with the exact same type of bulb.
DCAV8R
Feb 25, 2012 03:48 PM
JaceTun
Sep 12, 2009 01:28 PM
bihoang
Feb 24, 2007 10:54 PM
dtownhotcorner
Jan 31, 2006 06:39 PM
auto3251
Dec 5, 2005 06:14 AM
