how to ride with just fogs on?
Old Aug 15, 2008 | 11:14 PM
thedon28's Avatar
Default how to ride with just fogs on?
how can u make it so just your fogs are on and not ur headlights..a kid who has an audi told me he had his macanic rewire something..does any1 know?
Old Aug 16, 2008 | 03:53 AM
audiprotein's Avatar
02 models can do that, all others cant without rewiring them.
Old Aug 16, 2008 | 10:42 AM
rhyab1's Avatar
I am about to find out from my installers real quik....
Old Aug 16, 2008 | 11:54 AM
thedon28's Avatar
yea dont u just click ur leadlight switch once to the right then out and that should be only ur fogs??that dosent work for me..on audizine they say u got to vagcom it
Old Aug 16, 2008 | 03:39 PM
bustanut's Avatar
'02 B6 is simple vag com. >'02 requires vag com to "rest of world" plus a simple and reversible wire splice on back of headlight switch.
Old Aug 16, 2008 | 07:22 PM
EVOLA4's Avatar
It's a pretty simple mod, plus if you don't mind the running lights on then you don't have to re wire anything at all.
Old Aug 17, 2008 | 02:07 PM
pa4ul's Avatar
so on a 2003 b6 u need a vag or u can rewire?
Old Aug 17, 2008 | 06:15 PM
EVOLA4's Avatar
all you need to do is chage your countyr code to canada and the fogs will be on while your driving w/o headlights. The code I believe is 01014. Use Vag-com method so you can change it back later. I turn mine off in the summer because I live in the desert and reducing any bit of heat near my IC is a good thing. I turn them back on in the winter.
Old Aug 18, 2008 | 12:22 PM
LT1FirebirdSLP's Avatar
Where does one get this said "Vag-Com"?
Old Aug 18, 2008 | 02:32 PM
4Rings3Liters's Avatar
