how serious id my car problem?
Old Mar 18, 2009 | 08:42 PM
peroxi's Avatar
Default how serious id my car problem?
i went to the dealership just to get a simple oil change and i know it is a little expensive but i go there once every 3 times i need one, just to check up on the car.
today they said that the engine electric thermostat and coolant plug was leaking coolent----890$$$
coolent flush due to discoloration of engine coolant---381$$$
valve cover gaskets and cam adjuster seals leaking oil----905
i was kinda blown away and didnt know what to do. is this a serious problem??? and are the audi guys asking too much??
help me out guys
Old Mar 18, 2009 | 08:50 PM
shane.trammell's Avatar
hahahahahaha dont do it.
are you mechanically inclined? i did my thermostat, it was pretty easy. The coolant is supposed to be lifetime, but you can drain it all out when you do the thermostat.
Where are you located?
ee99ee's Avatar
That's all stuff you can easily do in a weekend. Coolant plug -- did they mean the Engine Coolant Temp (ECT) sensor? I had to replace mine not too long ago because it was throwing a CEL (Check Engine Light). I think it was $20? The thermostat is about $100, and I just replaced mine a couple weekends ago when I did the timing belt. Easy to get to on my 1.8t with the whole thing torn apart, but you'd need to pull the intake manifold I imagine without taking the frontend off.
I need to replace my valve-head seal too, it's leaking and makes everything ugly and messy.
Are you loosing coolant? Do you have a CEL? What year/type of car/engine and how many miles?
-Chris
Old Mar 18, 2009 | 09:03 PM
peroxi's Avatar
i have a 2004 1.8tq and 45705 miles on it over my winter break my cel light went on and i just added a little bit more coolent in it and realized there was a air bubble in it so thought it was nothing big. currently i'm living near rockville md
so i'm guessing this is not a big issue that i can do myself if i research it online?
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
