humming/droning noise, need help!
Old Sep 28, 2009 | 11:18 PM
muwenk's Avatar
Default humming/droning noise, need help!
hey guys my 02 a4 1.8T is making this humming/droning noise, coming from midsection underneath the car. doesnt matter whether its driving or just idling. it's also at times accompanied by a slight hissing noise.
any ideas? i used to get this last winter as well but it would go away after a while. is it the exhaust? or transmission?
thanks
Old Sep 28, 2009 | 11:30 PM
Dan1969's Avatar
If it's a hissing noise is probably something with your exhaust, if it's a humming noise probably clutch bearing.
Old Sep 28, 2009 | 11:45 PM
muwenk's Avatar
thanks! i was just browsing around the forum and it seemed like it could be a problem w/ the fuel pump as well?
i know there's tons of things that could go wrong here and i'm taking it to the dealer in a couple of days...just wanted to hear from ppl other than the dealership first so i know what to expect.
i never had this problem when the weather was warmer tho...stupid cold front...
Old Sep 29, 2009 | 07:05 AM
Dan1969's Avatar
The humming noise is normally under your rear passenger seat.
Old Sep 29, 2009 | 12:23 PM
pa4ul's Avatar
could ur be fuelfilter. Located near more towards the front of the passenger side rear tire. U can lift ur rear set up by pulling on it and seeing if it is the fuel pump or filter. Process of elimination.
Old Sep 30, 2009 | 09:44 PM
mikeeace's Avatar
Member
yea man i just got mine replaced... its the Fuel pump or filter.....it happens on start up and when your car warms up it goes away some times right??? i have a pre-own so it only cost me 50$ for the service...so idk how much it would cost you.... but im 99% sure that its the pump or filter..good luck
Old Oct 3, 2009 | 03:51 PM
Markow123's Avatar
Member
Ah i have this exact problem!
Is this a cheap fix ?
Old Oct 4, 2009 | 03:39 AM
mikeeace's Avatar
Member
well i have a pre own so it didn't cost me anything.... the dealership covered the cost.... but i would think labor is 100$ + an hr and the parts have to be at least 50+ .......
Old Oct 4, 2009 | 01:16 PM
muwenk's Avatar
got back from the dealership a couple of days ago. they diagnosed it as a bad fuel pump as other had suggested. labor (forgot the hourly rate but im in pittsburgh, pa) and parts (pump + filter) came out to be over $650...
Old Oct 5, 2009 | 05:50 PM
Markow123's Avatar
Member
650 oh good lord looks like i won't be getting that fixed!
It's not something that could lead into bigger problems is it?
