Idle Issue
Old Oct 10, 2010 | 11:30 AM
nickie's Avatar
Default Idle Issue
05 A-4 1.8 T , 6spd CEL is on..Car drives great. Come to a stop it goes from idle up to 2200 rpm's hangs there a second then drops back down to idle, then back up to 2200 rpm. Whats going on ???
Old Oct 11, 2010 | 11:03 AM
Ifty1's Avatar
Hi nickie
I have a 2004 audi 1.8t quattro with similar problem. Ideally you need to have a diagnostic check to see what fault codes are showing.
Based on the VAG Com on my car for the same problem, it first threw up the lambarda sensor which I changed then it gave me codes which related to Coils 1 and 2 which i also replaced.
Now I am getting the code 17705 - 'pressure drop between turbo and throttle valve p1297 upper limit reached'
I then cleaned out the throttle body but still have the same issue. The car idles rough and it seems to be drinking alot of fuel. I have also changed the coolant temp sensor and spark plugs.
I had a local mechanic check for air leaks via a smoke test but there were no signs of a visible leak
if its misfiring then it could be the coils however you should check this on a vag com first to be sure
Old Oct 12, 2010 | 07:35 PM
nickie's Avatar
Default idle issue
getting a code p0507 which is starting to point towards the throttle body. I cleaned i real good with spray cleaner and didnt make it any better
Old Oct 13, 2010 | 04:54 AM
Ifty1's Avatar
Thumbs down
Did you have a throttle body adaption/re-alignment done after you cleaned it?
audinoob88
Aug 6, 2011 09:45 PM
fullcollapse318
Jul 9, 2010 10:07 PM
karlossss
Feb 25, 2010 04:54 PM
a4owner
May 16, 2008 05:25 PM
Inibalir
Mar 5, 2008 10:49 AM
