K&N blows mass air flow sensor?
Old Dec 1, 2008 | 06:35 PM
Bltprf502's Avatar
Question K&N blows mass air flow sensor?
I recently installed a K&N drop in air filter. My car has been throwing a code that triggers the check engine light. I have reset it twice. From what I can tell from an OBD2 machine it is either an O2 sensor or the mass air flow sensor. I spoke to the service manager today at the Audi dealer and first thing he asked me was "did you install a K&N air filter or a oiled filter in the car?" My answer was yes of course. He said a very common failure for the mass air flow sensor was using oiled air filters. He said it happen frequently... Is this true? What do I need to do besides the sensor? He said if Audi sees you are using a K&N and your car is under warranty, if the mass air flow sensor blows they will not cover it. SHould I go back to the old filter?
Thx!
Old Dec 1, 2008 | 07:30 PM
DÌEGØs AÜD!CTIØN's Avatar
i got a short ram intake on my a4 and it didnt throw a code. try using that carb cleaner spray stuff to clean the MAF sensor... it should be able to take most of that oil off of it!
Old Dec 1, 2008 | 11:32 PM
Mike-2ptzero's Avatar
It is BS, its their way of blaming it on the filter. I have ran K&N filters on my A4 since I bought it new in 2000 and on my Eclipse that I had for 11 years. Never had an issue with them.
Maf sensors can blow out if they are pushed to their max all the time.
Old Dec 2, 2008 | 12:43 AM
krystallbluea4's Avatar
the oil from the filter if it is too "heavily" applied has a tendency to get collected onto the small wires of the maf. Get some CRC Mass Airflow Sensor Cleaner at local auto parts store and follow instructions on can. Takes about 5-10 minutes to do if you have the 5pt security torx bit. About 45 minutes if instead of the proper 5pt bit you have a dremel and a flat-headed screwdriver(ask me how I know). Either way its an easy fix. Probably a good idea to go ahead and clean the maf everytime you clean and re-oil the filter. Good luck man.
Old Dec 2, 2008 | 09:29 PM
Bltprf502's Avatar
Its brand new. No extra oil.
Old Dec 3, 2008 | 12:18 AM
Brand new are over-oiled from the factory. I shake mine off(not gently)after I clean and oil it, as well as clean the maf everytime. The reason it's a problem on these cars is because the turbo draws significantly more air at a higher velocity then a naturally aspirated(n/a) engine. The filter manufacturers basically soak the filters in the oil before packaging and for most engines (see n/a) thats not a problem because the velocity of the air will usually not carry the oil to the maf. Don't take my word for it though...
Old Dec 3, 2008 | 12:28 AM
^^^ yeah plus what do u have to lose?? 5-10$ on the CRC Mass Airflow Sensor Cleaner. compared to [ur other options/guess] a new MAF or O2 sensor...
Old Dec 5, 2008 | 11:53 AM
ppgoal's Avatar
I have heard the same thing on the A6 forum. Either shake the K&N or let it drain real well before re-installing. I've had one for 50k miles with no problems.
tuga.A4
Jan 9, 2013 06:35 AM
obryan44
Nov 8, 2011 01:44 AM
Nick_UltraSport
Feb 9, 2009 10:49 PM
vivanov1
Dec 4, 2007 04:32 PM
alexm999
Mar 12, 2006 02:49 PM
