Key fob still doesn't work after a new central control module
Old Jul 2, 2014 | 11:30 PM
slowaudi908's Avatar
Default Key fob still doesn't work after a new central control module
i been having problems with my key fob the car gets the signal but doesn't lock unlock. I ran it on vag com months ago and this is what i got
Address 45: Inter. Monitor
Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
VCID: EBD5899199BC1146DE5-5122
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
01560 - Passenger Door
01561 - Rear Left Door
01562 - Rear Right Door
People said to buy a new Central control Module and i did. Finally by the help of one of our members i installed it but never programmed it . Right now the key still doesn't work but still gets the signal i am lost should i try to reprogram it ? no clue on what to do .
Old Jul 3, 2014 | 09:05 AM
Exuberantt's Avatar
Try to reprogram it.
https://www.audiforums.com/forum/showthread.php?t=208883
Gonna do no harm and it cost nothing. Cheers
Old Jul 8, 2014 | 01:40 PM
tofast2belast's Avatar
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
43-00 - Closed
37-00 - Faulty
35-00 - -
35-00 - -
35-00 - -
35-00 - -
you need to pair the keyfob to the CCM, the ccm will see any frequency is with in operating range..
so the encryption key needs to be stored/adapted in order for the CCM to accept any command from the keyfob.
Ross-Tech: VAG-COM: Remote Control Matching Info
Programming Key Fob - AudiForums.com
this will not work because the keyfob needs to be paired with the CCM first.
HKS
Jun 9, 2015 02:05 AM
A3CUB
Aug 26, 2010 04:36 AM
cstew69
Dec 22, 2008 10:05 PM
gen2roller
Sep 4, 2008 06:36 PM
simon2406
May 2, 2008 05:05 PM
