LED lights
Old Mar 4, 2009 | 09:48 PM
itsmatt33's Avatar
every time i put in led bulb i get a error in the drive comp telling me my bulb
Old Mar 5, 2009 | 01:16 PM
pa4ul's Avatar
prob cuz u are in need or a resistor. where did ur purchase ur bulbs from?
Old Mar 12, 2009 | 10:01 PM
kent9272's Avatar
Pa4ul-
If I order the High Powered 9 Led SMT Festoon 10mm diameter - Direct drop-in replacement for all OEM bulbs for my 2006 S4, this will not trigger the light bulb out message? Thanks.
Old Mar 12, 2009 | 10:04 PM
Myst420's Avatar
Unless it has a built in resistor, it will trigger the message.
Old Mar 12, 2009 | 10:10 PM
kent9272's Avatar
Are you sure? Here's Pa4ul quote:
"i have led license bulbs and reverse lights. my plate lights work fine i order them from autoillumination for like 12 bucks or something there are 9led ones half way down the bottom of the page. no problems with flickering or not working or error codes. jus make sure they are over 12v on the led. pics!"
Old Mar 12, 2009 | 10:14 PM
Myst420's Avatar
It's possible, try them out and let us know. Worst case senario, you have to install some resistors (which is fairly simple)
Old Mar 12, 2009 | 10:17 PM
kent9272's Avatar
With today's economy, $20 is more like $50, lol. I bought two 10w 100 ohm resistor from Radio Shack but they are too big and won't fit.
Old Mar 12, 2009 | 11:20 PM
  #18
Myst420's Avatar
Here is the resistor I used for the tail lights. You actually only need one resistor for both lights. I would offer you the other one in my set, but I ended up melting it by mistake
Old Mar 13, 2009 | 12:22 PM
  #19
pa4ul's Avatar
OKay from my understanding when i purchased these bulbs on the website it says the bulbs are 14 V Rated so that is more then the nessacary 12v required to not throw a code. when u purchase the Led bulbs check to see what their voltage is. And tiestrap ur resistor to something that wont get hot or melt cuz that suckas get hot real real quick. Use gloves
Old Mar 13, 2009 | 12:55 PM
  #20
Myst420's Avatar
I wouldn't recommend tie-strapping the resistor, as it will melt the strap. I bolted mine down behind the lining of the trunk.
