Limp mod 5psi, direct to WG 20+psi
Ok so here's what I don't get. If I let the n75 control boost I'll push about 15-17psi then run limp at 5psi. So after screwing around a while I gave up and just jumped the boost source line from the turbo and ran it straight to the wastegate, well now I have no control over the max. boost. Whats the deal here? I'm going to check to make sure no lines are leaking, but is it possible that the wg actuator took a dump on me, or perhaps the wg actuator's stud has become thrown out of wack.
Thanks
Thanks
VorsprungMonkeyTechnik
Jun 28, 2015 11:53 PM
