Looking to Hard Wire Power
Old Dec 30, 2008 | 02:36 PM
Dan7007's Avatar
Default Looking to Hard Wire Power
Im looking to install a hard wired switch for my undercover warning light. If anyone can tell me an easy or good point to tap into the 12V power system?
Old Dec 30, 2008 | 09:21 PM
pa4ul's Avatar
what u mean undercover warning light? Second u can tap into the power but either running a new wire from the battery through the firewall and where excatly will this undercover light be going?
Old Dec 31, 2008 | 01:48 AM
borninrussia3's Avatar
do you want the power to be constant or only powered when the car is on?
Old Jan 3, 2009 | 10:11 PM
info@a4mods's Avatar
this writeup will show you where to get switched ignition power as well as a solid 12V
http://www.a4mods.com/index.php?page...urbotimer.html
Old Jan 4, 2009 | 12:50 PM
a4nate3.0's Avatar
Member
Undercover warning light? Radar/laser warning? Confused on what light this may be.
Old Jan 5, 2009 | 06:55 AM
Porsche2AudiHappy's Avatar
Yes there is an easy one in the over head console at the sun roof control. Check the DIY at A4Mods, under hard wired radar detector. They ran a ground al the way back to the fuse box. I drilled one right there. Took twenty mins.
Old Jan 5, 2009 | 01:03 PM
pa4ul's Avatar
i grounded my radar into a ground in the light housing. I forget where i did. Ill check it out and see cause my damn sunroof has gone awall. But the sunroof DIY is the best way to get power cleanly.
etsandy
Feb 1, 2015 12:45 PM
ooTToo
Nov 4, 2009 08:36 PM
james0013
Dec 4, 2008 10:56 PM
mr.cAp
Dec 29, 2007 11:01 PM
basementwaj
Dec 16, 2007 09:38 PM
