My car cant hold it in
Old Feb 11, 2008 | 05:17 PM
PandaXpress's Avatar
Default My car cant hold it in
well my baby is falling aprat
shes leaking coolant in 2 places
the gasket on the intake manifold and the water pump
a really bad leak, its basicly just pissing out coolant
and i am also leakin power steering fluid and a bit of oil
im also gonna do a timing belt job
boy things just guess worse for me
so im driving a red truck again
i call her big red
its in the shop now so ill keep u guys updated
hopefully it wont take too long
Old Feb 12, 2008 | 02:22 AM
audiprotein's Avatar
Default RE: My car cant hold it in
Good Luck!!!
Old Feb 12, 2008 | 02:19 PM
thanks i hope to get her back soon
casue this trucks drinks gas like nuthing
Old May 16, 2008 | 02:28 AM
The Orange Remix's Avatar
The dealer told me that my water pump is leaking. I've read that I should replace the water pump along with the timing belt and tensioner, but I'm only at 60K miles. Is it worth it to replace the water pump now or can it wait? It doesn't appear to be a very big leak.
Old May 16, 2008 | 03:01 AM
kezzi22's Avatar
i had a leak replaced for coolant recently too, it was the coolant flange...? anyway dealer acted like it was a normal occurance.
Old May 16, 2008 | 03:14 PM
Is that all you have to do for the water pump? Does it need to be replaced?
Old May 17, 2008 | 02:15 PM
Anyone have any opinions on the need to replace the water pump? Does it need to be done now? I'm not sure if this is a major issue or not.
Old May 17, 2008 | 10:13 PM
Leaking water pump is not good at all. It might cause your timing belt to fail... You better fix that asap if you have a chance.
Old May 18, 2008 | 04:39 AM
How does the water pump affect the timing belt?
Old May 18, 2008 | 06:22 AM
Remman's Avatar
The coolant leak seems to be a common occurance. Apparently one of the coolant pipes was plastic and cracking on a lot of vehicles, which has been replaced by a metal one.
