Need help, car is always low on engine oil.
Old Dec 26, 2010 | 09:07 PM
taevion0's Avatar
Default Need help, car is always low on engine oil.
i drive a4 b6 02' 3.0l, i have 2 problems.
1. My car has been showing the low engine oil warning around every 700 miles and i've been filling up a quart which i guess lasts me an estimate of 700 miles before the light comes on again, what can possibly be wrong with my car.
Before this problem, i had a mechanic that fixed an oil leak that i've had for a long time, i don't remember the details but it always ended up with my driveway having a foot's length size pool of oil.
2. My 2nd problem is that my windshield washer jets are really weak, when i hit the spray button, it squirts at most 4 inches, doesn't even reach half way past my windshield, what could be the cause of this and what can i do to fix it. I've tried using a toothpick to clear up the holes but that didn't improve it.
Thanks for reading
Old Dec 27, 2010 | 12:41 PM
Audi Tek's Avatar
Tech Certified
Are you still leaking oil...? And are you sure its the oil fill light (green) and not the oil pressure light (red)....?
Old Dec 27, 2010 | 03:21 PM
pa4ul's Avatar
as for the washer fuild. Try getting a needle and poke around those holes. Probbaly still gunk in their. Either that or ur pump is slowly losing its will to live.
Old Dec 27, 2010 | 04:29 PM
taevion0's Avatar
this isn't from my car since i got rid of the light by exiting the freeway (the last 3 times it's happened) but it's the same light i get
http://farm4.static.flickr.com/3317/...bacfe663be.jpg
And pa4ul , i did try to clear it up with a toothpick, didn't work, i guess i'll try again with a needle
Old Dec 27, 2010 | 04:30 PM
Audi Tek's Avatar
Tech Certified
What was the leak that was fixed....? 3.0L aren't really big oil leakers. They used to have leaks from the tensioners, The bolts come loose and work their way out and dig into the housings... but you would be puddling oil under the car
Old Dec 27, 2010 | 06:18 PM
taevion0's Avatar
Edit: sorry didn't answer the first part, but No, no leaks or puddles since i took it to the mechanic, i don't smell any burning oil either.
Also i just called my mechanic and he's like just keep filling it up the engine oil, it's ok..... as long as it runs lol...... maybe i shouldn't bring my car to him anymore. I asked him about why it leaked in the first place and he said it was because the engine overheated before and the header was where it was leaking from and he has since, changed the header or fixed it or something. I've never been hands on with cars, but i guess i'll start somewhere today...
Old Dec 28, 2010 | 06:17 PM
Audi Tek's Avatar
Tech Certified
Yea that guy sounds like a waste of space. I'd take it to a Euro shop or even a dealer.
The dealer will be expensive. But just pay the diagnosis, and shop around the repair. Compare prices. Cheapest isn't always best, especially with European cars. A "Good" deal is what you should be looking for
Old Dec 31, 2010 | 11:00 AM
muckdawg24's Avatar
Cam Seals are notorious for leaking oil. I've had two or three replaced. I have a 1.8L turbo and a plastic elbow that is mounted on top of the oil filter assembly cracked and crumbled.
Don't let a mechanic tell you "that's what they do" or "just keep filling it up." It's not supposed to leak. They are just lazy and don't wanna look for the problem.
Old Jan 2, 2011 | 06:29 PM
taevion0's Avatar
sorry guys, caught cold over the week, but i get what you guys r saying, thx for the help
i was sniffing around with my stuffy nose and i smelled gasoline around that round thing (dont kno what to call it) Is it normal?
omg how do i resize?
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
