NEED HELP! Oil getting into ignition coils causing EPC fault again!
Hey i have a 2003 1.8T s-line and i have recently run into a lot of trouble with this car. I have only had it for about 3 months and about 3 weeks ago i had an ignition coil go bad and my valve cover gasket got a leak... not a big deal had it all replaced along with the ignition coil wiring harness. Then another ignition coil went a day later and i took it to an audi dealer where they replaced all four coils under a recall. Everything was fine till today when my EPC light came on again today and i pulled all four coils and found oil in the coils again and it shouldnt be the gasket this time. the car has not been drive hard since start of problems and im about out of options, and the car is still not running right and i can tell it seems the same problem is coming back and im not happy because i have already dumped over 800$ into it. Any suggestions?????
