Need help with P0722 code
Old Aug 15, 2014 | 04:45 PM
DSMBoost's Avatar
Default Need help with P0722 code
I have a 2004 A4 1.8T with the 6 speed tiptronic transmission. I'm getting the p0722 code. No obvious issues with the transmission or speedometer. The only issue that might be related is when accelerating from the stop, the car will significantly jerk if I don't let it start moving on it's own and ease the throttle slowly.
I've searched and I've seen everything from replacing the TCM to replacing a single sensor or various combinations of the two depending on other factors. Can somebody shed some light on this?
Old Aug 30, 2014 | 09:58 PM
DSMBoost's Avatar
Anyone have any ideas at all?
I found this but I'm not sure what it's for. Could not find this part in any Audi parts catalogs..
http://www.ebay.com/itm/Auto-Trans-Output-Shaft-Speed-Sensor-Standard-SC198/111440944625?_trksid=p2050601.c100272.m3467&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140813112422%26meid%3D6dcd1694d068492ea4fb3ff8eaff44a9%26pid%3D100272%26prg%3D20140813112422%26rk%3D1%26rkt%3D4%26sd%3D111440944625%26clkid%3D188147283671619237&_qi=RTM1562569
Old Aug 31, 2014 | 02:29 AM
Pablo_Ottawa's Avatar
Google that code more to get a better feel of what the issue is. Don't just go to one site and decide that you know what it is.
That said, I got the same code and replaced the speed sensor shown above. It took care of my problem but codes can be tricky to diagnose as one specific code can come up as a result of various failures, be it sensors or other components.
The sensor itself was not too hard to replace, just google that too and you should come up with a good write up
Old Aug 31, 2014 | 11:04 AM
DSMBoost's Avatar
I've googled the crap out of this code and searched every audi forum. I can't find anything about the sensor above and the most common answer I found was replace the TCM on a CVT. Do you have a link for a writeup on replacing the sensor above? If not, do you know the general location of where it's at and how to get to it? I'd appreciate the help.
Old Aug 31, 2014 | 07:06 PM
B6 A4 1.8T replace the speed sensor
Old Sep 1, 2014 | 01:06 PM
DSMBoost's Avatar
Searching this brought up references to the engine speed sensor. Upon further searching, I learned the speed sensor part above is the Vehicle Speed Sensor G22. I can't find information on where it's located though on a 2004 cvt.
Old Sep 1, 2014 | 01:11 PM
I have a Quattro and I replaced it on the left side of the engine. Since your engine is transversely mounted it will be at the back near the bottom. Or at the front. You'll have to use your brain to figure the rest out.
That's all I got.
Old Sep 1, 2014 | 10:20 PM
DSMBoost's Avatar
That's all I got.
According to this, you have to remove the transmission oil pan to get to the sensor. Does this seem right?
http://ww2.justanswer.com/uploads/PE...20558_audi.pdf
pb_beaker
B7 Models
Oct 6, 2010 01:02 PM
DSMBoost
Jul 17, 2010 04:08 PM
shmeker
Jun 24, 2010 04:50 PM
dukesean
Mar 25, 2010 01:46 AM
dark_wing_duck
Mar 13, 2008 09:08 AM
