New 2004 A4 owner need advice please (HID fuse)
Old Mar 10, 2014 | 07:45 PM
rr1982's Avatar
Default New 2004 A4 owner need advice please (HID fuse)
Hi I'm new here, just bought an '04 A4 3.0 manual with the HID headlights, I love it! However the right side headlight is showing "dipped" on the screen I bought and replaced the bulb, but it still doesn't work. I looked for a fuse in the driver's side dash fuse panel, but there isn't a fuse for the HID's. Does anyone know where the fuse or breaker is for the Xenon lowbeams please? Thanks
Old Mar 11, 2014 | 01:39 AM
rr1982's Avatar
Anyone?
Old Mar 11, 2014 | 11:51 AM
pa4ul's Avatar
its probably your ballast that went dead on you.
Old Mar 11, 2014 | 07:41 PM
rr1982's Avatar
thanks but do you know if there's a fuse or circuit breaker?
Old Mar 12, 2014 | 12:44 PM
pa4ul's Avatar
do they other lights in the housing work I.E. signals high beams? DRL? If so its a bad ballast......
Old Mar 16, 2014 | 01:40 PM
rr1982's Avatar
Took it back to the dealer i bought it from, his mechanic took the light assembly out, moisture got in and corroded the xenon ballast control module
Old Mar 18, 2014 | 06:00 PM
pa4ul's Avatar
did they replace it and if so did it fix the problem?
Old Mar 19, 2014 | 09:32 PM
rr1982's Avatar
He told me to seal the light assembly with silicone windshield sealant and get a ballast off ebay, but I took the lights out and the ballast off and let it all dry in the house overnight, sealed the assembly,blew out the ballast with my compressor the next day, put it all together and it's been fine.
pilotike
Nov 20, 2014 08:35 AM
cudafish
Aug 3, 2013 06:01 PM
Dalakian
Nov 4, 2012 10:29 AM
nuggett10
Nov 2, 2011 07:40 PM
CasopoliS
May 22, 2011 12:15 PM
