New to the forum... oil question
Old Aug 15, 2008 | 09:48 AM
guitarc's Avatar
Originally Posted by auditech79
NEVER EVER put a FRAM on your CAR!!!!!!!!!!
FRAM filters and others like it DO NOT HAVE A BYPASS VALVE IN IT.
So if the filter were to ever get clogged your oil pressure would go down to zero, and if your oil pressure is at 0 while driving.............................BOOOOOOM goes your engine. Spend the extra money and buy the correct filter.
Doesn't Audi have the oil bypass circuit built into the pump? If not, I could see a lot of 1.8 engines going kaboom. If that was the case, poor engineering. I need to see the oil flow circuit on this engine before I come to conclusion tho...............
The reason I feel that the larger filter is used is not so much for added capacity is a larger filter surface to collect contaminants between the oil changes so the bypass circuit would not come into play and pass the junk back into the engine........I need to see the oil circuit.....
Old Aug 17, 2008 | 10:22 AM
jhsteel82's Avatar
Whats the amount of mileage before an oil change w/ the fully synthetic oil. Change it every three thousand? Also seen every 5 thousand?? Or is it still change the filter every 3 and the oil and filter every 6?
Old Aug 17, 2008 | 12:42 PM
auditech79's Avatar
No it doesn't, and it is poor engineering. Thats why there is a world wide TSB for fixing sludge/oil pressure issues. Look up the sludge TSB if you can find it, it will explain exactly whats wrong with the original design, its only on the A4 1.8T's, the TT 1.8's don't suffer from the same design issues.
Old Aug 17, 2008 | 12:49 PM
KINGBAT's Avatar
Royal purple been running it for a little over a year and it has done great on my a4..
Old Aug 17, 2008 | 12:50 PM
auditech79's Avatar
Royal purple is what i run, it seems to stay quite clean up to 5k as well.
Old Aug 17, 2008 | 12:55 PM
KINGBAT's Avatar
Exclamation Kinda issue
I HAVE a 01 a4 quattro 1.8t slightly modified and have a power issue.
i'll be driving and al of a sudden the car will hickup power. and when i first got the car it was almost scary how it would pickup and immediate throttle response now not so much. lastly i prev could be in 4th down shift and spank past most cars now it will rev but no power sometimes what can the prob b this is driving me nutzzz.
Old Aug 17, 2008 | 12:58 PM
auditech79's Avatar
Thats not enough info, does your car have a CVT transmission or quattro? You also need to pull the fault codes and open another thread about the issue posting the fault codes.
Old Aug 17, 2008 | 01:02 PM
  #18
KINGBAT's Avatar
quttro the only code is catalytic converter temp.
and I cant figure how to open a new thread
Old Aug 17, 2008 | 01:04 PM
  #19
auditech79's Avatar
At the top of the page in the B6 main page there will be a tag saying new thread, just click it and start a thread you will get more attention this way.
Old Aug 18, 2008 | 07:47 AM
  #20
Pablo_Ottawa's Avatar
Originally Posted by akarol
Considering the life of a car is the oil changes, I have never skimped out on it and have always taken it to the dealer for full-synthetic. Apparently, they use a custom Castrol Syntec formula that is only found in affiliated dealers and specially made for the related cars. German cars can't take much alteration as American cars and require very precise handling. If you stick to what it asks to the point, these cars can last you a lifetime.
Read the label on the back of the pics I posted.... The Castrol Syntec in the pics IS the oil they use. I agree with you, German engines can last you a lifetime if you treat them well with regards to oil and the exact fluids they require (My old GTI with over 400k).... I'm super **** about the oil I put in my engine which is why I wanted other peoples opinions on the the oil I purchased. So far from what I've read, this is the oil the dealers use.
